hub kit
does anyone have or know where i can get a steering wheel hub kit that will work with the hicas? i have just bought one that is supposed to be for the 300 and the connector on the back is totally different. if i remove the hicas sensor the hub will fit but the horn sounds every time i turn the wheel!
In my case Mike that would be a safety feature! Sounds like the horn is completing it's electrical circuit with steering column. I've not pulled mine apart but there should be a insulating sleeve for the cables down the centre of the spline.
is removing the hicas going to make the back do weird things or does the hicas stay in the same place?
Hi Mike,got a special boss from Smithy which has the hicas link also three buttons on the top of it for cruise control,give him a ring........Good Luck...........Vinz
Deffo sounds like an earth problem dude through the steering column.
