Cant get any gears
Strange problem after going sideways and up a kerb at the weekend. Had the car on a ramp and 4 wheel aligned and everything ok. Checked everything - ok. When she's cold it doesn't seem to want to go into gear at all. When it's in gear it seems to be creeping foward like the clutch isn't clearing properly. Could the impact have caused this? Doesn't seem to be any damage underneath. After she's warm seems to almost fall into gear. Is this air in the clutch fluid system? Or low fluid? Does anyone have a pic of where the clutch fluid reservoir is located?
Ivan
Hi,
Your clutch fluid reservoir is just to the right of the brake fluid reservoir, between the manifold and the bulkhead. It is on mine anyway. HTH
Baz
Really sounds like air in your system.
Cold- When u press the pedal the air is compressed.
Warm- The air in the system expands giving you some control over the clutch.
Question is how did air get in?
Best off checking for leaks matey.
