ecu reset
to reset the ecu do you turn the screw on it and back after 3 seconds
or do you have to disconect the battery for a few hours
or do both
also what sort of boost is safty boost (preasure) ?
steve
Safety boost is 7psi.
You disconnect the battery for at least an hour to reset it.
Turning the ECU screw one way wait 2 seconds then turn it back puts the ECU into diagnostic mode.
Sorry. Is that wrong? It seems that most of the stuff I say is BS!
Agree with srrae, turbo gauge won't go over half way
on + side when in s'boost.
Turn screw again for 2secs to take out of diagnostic mode. :)
thanks guys
look at that tomoroe
steve
thanks guys
steve
By "reset the ECU" do you mean "clear the fault codes" or do you mean "reset it so it relearns everything".
For the former you just need to put the ECU in diagnostic mode and then return it to running mode. For the latter you need to disconnect the power for a while.
the latter thanks mate
steve
If you disconect the battery, then place you foot on the brake pedal for about 30-40 sec's then that will drain all the electric left in the system (save waiting an hour or so) the re-connect and go for a long drive so that the system re-sets it self....this is how i was shown :D
nice one
steve
