Hi,
Had to do some mods for the power steering belt from my NA to fit the TT engine I put in the convertible!
The trouble is the stock PS belt now is too big for the the system, I think the stock belt has a 920mm circumference, I need something smaller and wondered if anyone might know of a source?
you could try taking it to a motor factors to see if they could match one up (or not quite match one up as the case may be!) :)
Mark, just had a look in the books. The stock one should be a 925 4R so you can use either a 920 a 915 a 900 or even an 885 if need be. QH part no. will be QBR4 followed by the length of the belt so a 900 will be QBR4900 you should pay around 6 quid for it. all the best.
also if you wanted a 'nissan' part you would either have to get an alt belt for a 1.6 100nx (without power steering model) this would be a 915 4R. The next smaller is a 884 4R which is the part for a 2.0 nissan prairie P steering belt!
