hi all, when my cars idling the drivers side exhaust note is real fluttery, kinda a flat note, but the other side is a nice deep note, as soon as you press the throttle it changes so there both the same note, this is starting to anoy me as when my turbo timer works and im walking away i can hear it very clearly,
any thoughts as to what this could be or what i could adjust??????
91 tt auto. straight through system (no cats) only back boxes.
cheers
Jim.
IS there any one out there...................
Clean the aivs out....
hi andy, Ive removed the Aiv's mate but still I get that anoying flat note, do you have to disconnet battery after removing the AIV's?
And what else could be causing this now?
thanks mate
Jim
:confused: i think i have the same prob but it seems all the time like a flapping noise in the right exhaust!
what are the aiv's?????????????
do a search mate there tones on this! and removel diagrams
jim
ive got this too, doesnt really concern me but it would be good to know why.
Have you guys not got a balance bar or H bar in your zorsts ?
What do the AIV's do anyway?
Is it a good idea to remove them?
Have read the removal article, seems pretty
straightforward.
I've got a single exit HKS super drager, it makes
all kinds of weird noises, would removing the aiv's
help? :confused:
yes, sure do
I have no balance bar, did cross my mind and thought of maybe having one added???
yer mate it sounds like that, sort of pufffing/flat note, drivers side sounds great!
it seems alot of us have this problem, surely some one must know the cause or cure??
jim
should I reset ecu after AIV removel?
cheers.
i noticed a similar thing but when i checked the back boxes one was cmopletly baffleless and the other was newish and of course most of the gas was coming out of the empty box causing a different sound on one side dunno what effect it has on engine though if any
