fault 34
just done a ecu diagnostic test
result 34
detation sensor circuit :confused: :confused:
what the f@@@ is that?
steve
Hi Steve,
Do a search, you'll find loads about it. Try cleaning the connector first :)
Vijay
ive done a search
didnt come up with anything
steve
search for "code 34" and "det sensor" :)
Vijay
thanks mate
steve
and try
"Detonation Sensor"
and not
"detation sensor"
Im the official dyslexic one here ;)
The ECU uses the detonation sensor to detect if the engine is suffering from detonation due to overboost / lean running / crap fuel etc.
It does a few things: Puts the system in safety boost (if the stock solenoids are still connected). Sets the ECU to use different fuel/timing maps (presuming the code you run has them - some tuners don't)
Basically if you have an aftermarket boost controller and JWT chip then you'll probably not notice a difference. If you don't you'll be running down on power.
Stevo
what have you done to her :( :(
broke her i think mate.
hows yours going done the tapits yet
steve
so if there is a big air leak like big turbo pipe split
detonation sensor would detect it and show code 34
steve
ok thanks mate
steve
John,
I was told yesterday that the JWT does not have any saftey maps and basically has 2 identical maps - do you know if that's right?
Vijay
for the record, detonation does this kind of thing to your pistons
when code 34 is showing the car will be running safety boost, code 34 will only show if there is a malfunction of the sensor, not if detting is occuring.
ow
looks like that hurt
steve
Stevo all the lifters turned up this pm from courtesy cannot belive how quick we can get parts etc from the good ol U S of A and saved a bundle even with postage!!
so will start on her this weekend
all the best with FEM!
cheers
Dave :hyper:
No, it shows code 34 because the sensor/wiring is bust I think!
There is a way of bypassing the detonation sensor, not
sure what it is though, use's a transistor from a tv or
something like that! Obviously if it actually is detonating,
then this ain't gonna help you, chances are, it's the connectors
getting gacked up though.
If you do bypass it and the car does start detonating, then
you ain't gonna know....until she goes bang! :(
As someone here posted tho - the det sensor only picks up detting below 3000rpm?
Can't remember the exact range it picks it up but it's only at a fairly narrow rev band and pretty high load from memory.
TBH, if you've got a boost controller and JWT/SE ECU, then you don't really loose anything by bypassing it anyway.
