Fog lamp bulb replacement???????
Right, I did a search for this earlier, and came up with this, that I thought would help me,
http://www.twinturbo.net/ttnettech/glareguard/glareguard.html
But this is the US version, without the side light included, so what I want to know is, is this the same procedure for removeing and replaceing a Jap spec fog lamp??? All I want to do is replace the bulb.
I've found a screw on the front of the lamp unit, but that just turns and does nothing :confused: The prob is that it was turning dark after I found this link, and couldnt be bothered to scratch around with a hand lamp :D
Many thanks in advance for your help :)
Dave :hyper:
You need to remove the side light panel - then you can access the bolts for the fog lamp - The screw you turned is for aiming the beam.
Cheers Bilky, i'll av a look tomorrow, if it fvkin stops raining :mad:
That only took 2 1/2 hours for someone to answer :confused: does that mean that no-one else on here knows either ;)
Dave
