EGR removal and low rpm detting!!
Hi,
I have removed the EGR system on my Zed and believe that a few people have experienced detting at lowish rpm about 3K, once this is done?
Did you have to get it remapped to get rid of the detting?
I am not too sure. But I have heard if you want your car to run really well you dont get rid of it, you change it for a newer one.
Stuart
Stuart
The exhaust gas return system cools the cylinder temperatures and also helps with emmisions control, it can be a real PITA, as it is temperamental and can cause problems if it goes wrong. Also it is an engine out job if it does go wrong and it is very debatable whether it would make the car run better and what do mean by better?
I hope you guys sort this one as my engine is out and I bought a brand new AGR valve in my pile from Courtesy and may need to sell it!!!!! :confused:
Stuart
REMOVE the EGR!!! Can't see how you'd get detting as the EGR should be tight shut at WOT and thats the only time I can see cylinder temps high enough at those revs :confused: Just get it remapped if you're worried...
CheerZ,
Andy
