Noticing the fuel gauge was very low this morning - I pulled into my local jet and put 45 quids worth of unleaded in. Pulled away and all was fine. About a mile and a half later revs drop and car starts stuttering and stalling. After furious pumping of the accelerator I can get it to tick over as long as I keep pumping the pedal. Car dies. Leave it for 10 mins - starts up fine. After a few juddery minutes down the road car seems to pick up and be fine again. another half a mile and car dies at lights. Many presses of pedal later I can get it to start and hop away from the lights. Then car picks up again and seems fine. Just managed to get home and car is revving through the range again and seems ok. Thing is its raining and I dont want to risk breaking down now. I checked the conns on the AFM but sure its not this as it revs above 3k. I have checked my air filter (HKS) and its as dry as a bone. Seem slike water in the fuel?
I rung up the petrol station and they said they have had no complaints and untikl they get some it must be my car.
Any ideas people?
siphon some out and keep it sealed - see if anyone knows how to get it tested....Try some Octane booster.
PTU maybe?
When the MAS fails it wont let your car go over 3000rpm.
Stuart
whereabouts is the PTU?
Do I just clean conns?
If I leave it will the water in the fuel (IF thats the problem) just evaporate? out?
thanks
1. Air Intake Hose
2. Turbo Hose
3. Power Steering Reservoir
4. C.A.S (Crank Angle Sensor)
5. P.T.U (Power Transfer Unit)
6. Windscreen Washer Bottle
7. Engine Coolant Tank
8. Fuse Box
9. 6 Coil Packs
10. Oil Cap
11. Radiator Cap
12. HICAS Solenoid
13. Radiator
14. E.C.U. Water Temperature Sensor
15. Dashboard Water Temperature Sensor
16. Fuel Filter
17. Brake Fluid Reservoir
18. Clutch Fluid Reservoir
19. Brake Servo
20. Air Filter
21. Throttle/Cruise Control Cable
22. TPS (Throttle Position Sensor)
23. Passenger Side Stock Boost Solinoid connector
24. Driver Side Stock Boost Solinoid connector
25. Driver Side O2 sensor Connector
26. Det Sensor Connector
27. Passenger Side O2 sensor Connector
28. Fuel Damper
29. Fuel Pressure Regulator
30. Balance Bar
Hope this helps you.
I think it is more the MAS. PTU have the habbit of stalling the car and then wont start for a while.
MAS will cause the car not to rev over 3000 rpm.
Do an ECU check and if it is any of those parts it will tell you
Stuart
Found the PTU - thanks
Wheres the MAS?
Done an ECU check - all ok
It will rev over 3000 but after half a mile or so car will start sputtering and die. Takes a fair while before starting again. I have just put some dry fuel (Wynns) in which removes water and cleans injectors and I also added some Octane Booster. Still got probs.
Car seems sweet for 5 mins then like I say, splutters and dies, takes 5 minutes to start again, sounds and feel like water in intake then just cleans itself out and goes really well for next mile or so.
This is really doin me head in coz I dont know If its fixed when I do something.
Any last ideas before I join the AA or RAC or take it to my local (Never worked on one of 'em before mate) garage.
