Z Set Up Help..........
Anyone help???
My Z now has M's (K&N) air intake, Scorpion Zorst and bleed jets (valves, whatever!) I know my Z is not chipped as it shows a standard ECU on conZult software, so I wanted to know if;
I needed to get it chipped?
or
Could I get mine 're-mapped' for the mods I have?
Or does anyone have any other idea's?? I just want to be sure that it's running at it's best.
Thanks in advance.
Matty.
an off the shelf would be fine IMO for those mods. a custom mapped chip may be better but will cost a lot more
Cheers Paul, what would you recommend??
Matty.
se nissan did mine car runs a lot better smother pick up seems quicker and a bit more power. 332 bhp on rolling road no chip (exhaust, air filter , boost upgrade 12 psi F8cked actuater's )
with chip 381 bhp 16 psi
turned down to 14 psi 367 bhp peter did tell me why it was better a this pressure but it went in one ear and out the other, no resistance in the middle ?
but they did pull my pants down when it came to charging.
se nissan did pull my pants down when it came to discharging.
Sorry to hear that Russ........;)
Thanks to you both for your input......:)
Matty.
A JWT chip or similar will be fine. You will need your ECU socketed for that.
Then if you wanted to go a bit further you could strip out your bleed valves and fit a boost controller. They needn't cost a fortune, the GReddy Profec II is about £250ish.
