Is it worth getting a 1 peice prop shaft?
Why is the stock one in 2 peices to start with? Is it so it can flex when going over bumps and cause less stress on the diff and box?
Trying to think what could be causeing my speed related vibrations in my car. The tracking is correct as is the balancing. There is a possibility that one of the wheels has got buckled.
The only other thing I can think of is the centre prop bearing.
I was wondering if it is worth getting a 1 peice one. It is a little bit lighter than OEM and more than strong enough, but should save a few HP because there is no bearing to turn and no centre joint to lose power.
What your thoughts?
Stuart
  • Replies 28
  • Views 938
Jaffa where do you get the carbon fibre one piece from sgp make a alluminium but carbon Fibre is certainly the way forward
Acpt has 1 for $1200 and Greddy has 1 for 320000Y that would be around 1500ukp
