Hicas Disconnection
Disconnected my Hicas at the RR day (thanks Mr Dixon) well what a difference the car is now stable at slow and high speeds , corners can be taken with the confidence that you will come out the other side , it's also really easy to get the back end out and hold it there without having to fight the steering wheel , without a doubt my best mod yet :D
Cool, will try this then - can you post a pic of the connector to short? I think I can remember but wouldnt wanna get it wrong lol.
Does the warning light light up?
Pete
that would be an intresting mod
if you could post details please
cheers antonio
Pete
will take a picture for you tonight mate , light should come on although mine has no bulb :confused: only takes two seconds to do aswell :D
Do you think this might be a reason why my car was a pig to control? Therefore leading to it's demise?
It seems a bit convienent that the HICAS light came on only a few weekends before only on a long straight!!
Just a thought...
Give me yours...
Ben
If the HICAS light comes on after driving in a straight line for a while it's usually because the steering wheel is off centre.
Just a thought...
Give me yours...
Ben
I've never had any gripes about HICAS.....
Bilky is yours an import or UK , I think this will affect the imports due to the speedo conversions , I have had the speedo conversion done but according to the Conzult, the ECU is still reading the speeds completely differently from the actual speeds being done , this will throw your HICAS off i.e I am doing 100mph and the ECU thinks I am doing 60 , make sense ???
Mines an import but the speedo hasnt been tampered with - it had a mph conversion sticker over the face....Maybe thats why its behaving...Yes - makes perfect sense - You could get a uk speedo to sort t out...
I did put UK clocks on mine and I still hated it.
Guess it depends on your driving style etc. too.
UK car but I don't really notice it... Always corners like it's on rails so maybe I would miss it if it wasn't there.. :confused:
Steve
'93 UK TT Manual
Wouldn't mind trying it without HICAS..........
Will follow this one with baited breath for pictures etc.........
:D
Matty.
