Windscreen Wiper arm shrieking!
I thought it was my wipers making the noise but its coming from the passenger wiper arm fixing point where its driven by the motor - I can unscrew the nut off but I can get the arm out to see if theres any way of getting some grease in there- WD40 sprayed around it didnt seem to help....
Any pointers appreciated.
Hi, just thought I'd let you know. I got a new pair of plastic panels that fit under the wipers, six monthes aggo. Four times I tried to get the wipers off, four times I failed..
I have now been told to try a two point pulling tool from Halfords,They are on straight splines so it should be a straight pull off. My wipers squeek like ****, so I hope with the panel off I can get to the motor. There must be a grease point in there..
Chris..
Sounds like the same thing! I guess the pulling tool is the answer. Might drop into Nissan on Sat and see how much they will charge to do it as its not like I really need the tool for other things.
I bought a silly little puller - about £3 from Wilcos - did the trick and removed the wiper arms easy. Since then they come off without the puller - possibly because I greased them before putting them back on...
have you got a pic or a name so I can get one?
...give me your address and I'll post it to you. I doubt I'll ever use it again. And if we ever meet you can buy me a pint...
cheerz
Jack
