Could this be a cheap "Tectom" ?
Andy, I don't know about the tectom but I've a multi checker perminantly in the z sitting above the clocks I find it quite good, lets you keep an eye on all sorts. ask lymon and do a search on here, cause I've posted before
Pete :)
The apexi multi checker works for all nissans but i cant remember but it might was designed only for the z32.The price is low because the multichecker is an old product.There are a lot of monitiring devices for the nissan
Got an email from Japandy!
He says it works with the Z32 but has to be spliced into the loom.
Pambos what other monitoring devices are there for the Zed apart from the consult/techtom and the Blitz R-VIT?
There is 1 by Sard and the other software from the states siniliar to consult the Nprobe. Personally i would for the Sard i'll find some specs and post them.
Also below some info i asked about the Techtom M-100 and their lauch control
[Hi, the MDM 100 does not require any additional sensors. It just plugs into
the consult port and gets all the readings from the ecu. The IIC can be
installed w/o any problems on a daily driver]
1 of the reasons i was suggesting an engine man for the z on the other post about the turbos was regarding monitirong also.
When the AEM is finished i'll get one because there +except from just a tunable ecu it has monitoring for all the sensors,it has lauch control and nitrous control for the future!
Cheers Pambos, looks like a bargain at $235, is that £125 now!
Shame it doesn't monitor knock, but you can't have everything
Mark for knocking i would suggest HKS A/F knock amp a bit expensive but i think hks has the best electronicks than the other companies
To be truthful I have already got a KNock amp, from spl parts , it is specifically for the Z32 and I hope it works will let you know!
