Just swapped Stock Filter And Put In An M's Filter
Just changed my old air filter (stock one) for an M's air filter, will I notice much difference (not out in it till later) and what 'should' I notice??
Cheers for any info fella's!
:D
Matty.
QUOTE]
Little bit more power overall and a bit more responsive at the bottom end, and different induction noise of course. Usually makes all the other bits like tubbies and recircs louder.
I've seen posts where ppl have had problems with water getting in because the splashguards are designed for stock, be aware!
Never heard of M's... :confused:
M's is mainly used on Jun tuned motors from what I've read........It's got K&N under the big M in the front of the filter......
Splash gaurd? What spalsh gaurd..........mine was removed when I had 99 spec front bumper fitted.......I'll see how I go....
Matty.
hi matty
i've got m's filter fitted. (came over with it on). had no problems wiv it at all. sounds good as well (compared to one i tested without)
nick
hi matty
nick
Cheers mate, will be giving it a run on way to Thor tomorrow, should get a feel for it then......put it on today and run a little bit of sealant between the join of new and old when I bolted it together........so I tohught I'd wait until tomorrow for it to go off, althought I can't wait to get out in it!! :D
Thought I'd ask if there was a difference in performance with it on as I have a Scorpion Zorst, so breathing is far easier for the Z....
As mentioned by Zevans it sould give more bottom end so I'm looking forward to that!!!!! :dance:
Matty.
QUOTE]
had this very same problem this evening with water getting in and hitting the MAF , nursed her home for 5 miles having to drive under 2.5k , hope she is ok for THOR tomorrow
