protoj · Tuesday at 18:48 3 days
Have been offered some nearly new HKS Hipermax II coilovers for the swb version s. (if i get it)Will these fit the swb ok as there probably off a 2+2. For fast road use only are coil-overs overkill or for the right price are they worth having. Is this a good brand or is there a better recommended one as ive no experience in coil-overs.
