T-Top drain pipes and new seals
Hi-
Can anyone advise- where do the t-top drain holes actaully drain to? and is there some pipe work in the pillars? Also- anyone know where I can get a complete set of new seals from and what they're likely to cost?
Thanks Mac, any idea on the drains?,
(I sent Ajay a cheque on 4th Dec- it hasn't arrived- lost in post me thinks (and no-ones tried to bank/cash it) I'll send another,)
Leonard
Leonard
Leonard if you unclip your apillar trim,you will see a plastic tube;)It's probably blocked.
Thanks Mac, does the tube exit outside the car? (through the sill perhaps?
I had a damp carpet on the pass side, I stripped out the seats/ carpet etc and put a dehumidifier in it. It's now bone dry, but since it's rained I see a little wet patch on the floor at forward right hand seam and evidence of water inside bottom of A pillar , - any thoughts?
Simply remove the targa top on the leaking side and you will see a drain hole in the targa's gutter, pour water down this slowly and it should all come out just behind the wheel from the inner arch liner.
smithy
Hi Smithy, thanks for that,
I poured water onto the drain and it trickled out where you mentioned. However, when I did the same with the rear drain hole, the water then trickled out of the drain hole in the sill (Half way along the car below the door)
When I checked the inside of the sill box section I could see the water. Fortunately there is no rust in there but surely that's a rot trap waiting to happen?
Leonard
