Throttle position sensor
My mates auto is showing a prob with his TPS.
Can I unplug the one of my manual and test it on his?
I've got a spare used one if you want, £10? I changed mine unnecessarily a while back :)
I'd imagine manuals and autos the same.
Pete
Cheers Pete, Im seeing him this weekend - If he wants it I'll give ya a bell.
Pete, on a slightly different subject here :rolleyes: Im about to have a go at fitting that HKS EVC Boost controller and have been advised to set boost to std before fitting. Now im running about 11psi on both boost guages. Where and how do I drop this down, I have no idea what a bleed valve or boost jet looks like?
Hmm dunno anything about bleed valves but if you've got boost jets, they will be in the ?wastegate lines, situated under the big turbo intake hoses, going into the metal tubing down there, theres a write up here
Removal is the reverse of fitting and all that :)
Pete
