Moaning.......not the missus
Hi guy's and gal's
I have a loud moaning noise from the back of my UK 300ZXTT. Now it's always there in a straight line and going round bends but seems to get worse when turning right so loading up the left hand side. I know the rear subframe bushes are weeping fluid but I was wondering if this could cause the noise? I sure hope it's not the diff?
Also has anyone ever replaced/had replaced these bushes? How much of a job/what was the cost?
:eek:
Ivan
Wheel bearing?
Then its probably just the wheel bearing on that side......;)
I believe b19rks had the same noise,was a knackerd wheel bearing.
Tony
If you load a wheel bearing it makes more noise, if you load the other side it makes less. Mostly. As you have found out.
mine has started doing this today :( but only on high boost.
