BOV and DVs query
As far as I understand a BOV and Dump Valve are the same - just spelt differently. A Recirc Valve is what the 300 uses - right?
A recirc valve is used because the AFM monitors it - now in the Supra You could get away with a DV upgrade from a recirc as long as you used dual piston DV. Would this apply to the Zed?. If I get 2 DV/BOVs I presume I just replace the recirc valve and block up the recirc intake.
No posts to show
