I remove the fuel pump fuse from the engoine compartment fuse box, ran the engine to run it out of fuel so I could disconnect fuel lines, engine runs forever? how long does it take to run it out of fuel ?
John
Should only run for a couple of seconds at most, if it even starts.
Funny this happened on mine and I thought it had been bypassed for some reason (immobiliser?) but when I tried it again a few months later to install fuel filter and braided kit it stalled straight way as it should :confused:
Got the right fuse? ;)
Pete
Pete,
It maybe my Toad immobiser then, mine ran for several minutes, I finally gave up and switched off.
I broke the clear plastic cover from the top of the 30 amp fuel pump fuse. It still works, but I want to replace it, is it a Nissan only part, or can I get it from somewhere else.
John
I think they're the universal ones (anyone confirm?), if so they cost 50p'ish each from any motor factors or most petrol stations.
Its like a square cube thing, not the usual blade fuse.
I can try Halfords I guess, I dont recall seeing anything like this anywhere.
John
From nissan they aint cheap - around £8 I think.....but they always have them in stock....Never seen any in Halfords.
Yes Bilky,
they appear to be a Nissan "fusible link" £10 each.
I dont understand the difference between a fusible link and a fuse, except 20 times the price!
John
