Wiring through bulkhead
Does anybody know the best place to drill or preferably use an existing grommet in the bulkhead. I have to run a fairly hefty power cable to an amp in the boot and its a straight live connection. I dont know if there is anywhere under the dash I can take it from - the only thing I can think of is the battery as the cable is already fused.
Ta
Sitting in the car, look down at the passenger side footwell and on your left is a plastic panel, lift this off and behind and upwards is a gromet for pulling a cable through, this comes out behind the plastic wheel arch liner and you can follow it up to a gromet that sits behind the battery, ideal for what yer doing.
smithy
:cool:
if its an auto i did find that where the cluch pedal should link to the clutch it has been blanked off, i have fed some cables and boos hose through here!
I used the right side drivers side) - with bonnet up there's a grommet on the bulkhead - pop it and you'll see the light coming through from the drivers footwell were a cable goes through (I think throttle cable), plenty of room there for amp cable t go through. That's what I used.
It was also enlarged to take my a pillar pod meters.
Geoff.
