Over the months I have read loads of replies from people suggesting checking the electrical contacts of loads of different areas, most of them I have not a clue where they are or what they do.
It would be so helpfull to myself and others who are new to Zeds if someone could post a photo of the engine bay with arrows pointing to all of these contacts and switches and contacts that should be checked once in a while for corrosion.
Does anyone have such a photo, or could make one up. It would be much appreciated by myself (and lots of others I imagine)
John
Stuart, that link dont work mate - says I dont have permission?!?
That means it's working fine mate ;).
You are not a subscribed user so you don't have access to the private forums.
Cheers Pete, now is there a corresponding chart for whats what?
In exchange for £20 to Ajay: http://www.300zx.co.uk/forums/showthread.php?s=&threadid=23419
1. Air Intake Hose
2. Turbo Hose
3. Power Steering Reservoir
4. C.A.S (Crank Angle Sensor)
5. P.T.U (Power Transfer Unit)
6. Windscreen Washer Bottle
7. Engine Coolant Tank
8. Fuse Box
9. 6 Coil Packs
10. Oil Cap
11. Radiator Cap
12. HICAS Solenoid
13. Radiator
14. E.C.U. Water Temperature Sensor
15. Dashboard Water Temperature Sensor
16. Fuel Filter
17. Brake Fluid Reservoir
18. Clutch Fluid Reservoir
19. Brake Servo
20. Air Filter
21. Throttle/Cruise Control Cable
22. TPS (Throttle Position Sensor)
23. Passenger Side Stock Boost Solinoid connector
24. Driver Side Stock Boost Solinoid connector
25. Driver Side O2 sensor Connector
26. Det Sensor Connector
27. Passenger Side O2 sensor Connector
28. Fuel Damper
29. Fuel Pressure Regulator
30. Balance Bar
hint took
My 1st January wage and I will become an honorary member
