speed sensor
steering goes heavy at anytime then back to normal
worrying at any speed
catches you unawares
is it the speed sensor and does it take much work to get it off
will i lose all the power steering fluid when i take it off.
can they be fixed or do i replace them whole
how much ?
cheers anyone
89 non turbo import.
I dont know if turbo and non-turbo have different ones.
They are about £100.
You wont lose any steering fluid. The reason the steering goes hard is the power steering is speed related and so gets harder the faster you go. When the speed sensor stops working the power steering keeps turning off.
Quite easy to replace I hear.
Stuart
Get your head under there and check the connections on the wires first before shelling out!!!
thanks for that
p.s love the girly vid;)
i got the same model same year same problem at the moment.
bloody annoying still haven't tracked my where mine is broken.
seems very intermitent and sometimes starts working again at
2.5k revs.
going to replace the wiring to it this weekend let you know where exactly it likely to be if i can:rofl:
ok mate hope you have some luck in finding the problem.
