Me again.
So I have two questions:
RobHowl ·
Is this guy on drugs??????
http://myweb.tiscali.co.uk/kuddy/200sx/how_fast.html
Check his mpg for 300zx, it reckons 24.7??????
i just got mine and cant get more than 15ish, is mine dieing???
