Consult HELP!
Anyone got one of these? A real (old type?) one that is, not a ConZult. I've just spent ages pulling the thing apart to get to a dodgy connector... put it all back together and now it simply says:
HT-OS V1.04
Error 102
Bad directory
Boy, am I in trouble!?! :eek: It looks like there's a reset button, which doesn't seem to do much. Is there some sort of procedure necessary after the battery (the on-board lithium one) has been replaced?
Any help would be useful. Yeah, I've checked all the 'orrible ribbon cables.
Cheers Jock. Is that Danny the ConZult guy? I'll try him in a bit. Think I need to go fess up to the owner of said kit - kinda hoping he'll know more about it :confused: I was gonna take some pics cos it's not often you see these things, let alone in a million bits (3 double-sided PCB's FFS!) but it wouldn't seem fair to say: this is what the insides of a Consult (that won't boot any more) look like.
I'd have thought you'd have made your own Si!
Seriously though, the serial conversion bit is nothing, I've got a circuit diagram somewhere, a bit of software and off you go.
:D There's a lot of features in the Consult (/ConZult) that I'm not /all/ that interested in. I want to hook something up so I can tell what gear the autobox is in tho. So that circuit could come in handy. It's not simply 0-5V TTL coming from the ECU(s) is it? Converting that to RS232 levels is easy enough.
Does Lymon still come on here Andy?
Having fessed-up earlier, it's... um... being dealt with. I only looked at it as a bit of a favour - didn't expect it to forget how to boot! The owner was kinda OK about it. I shall leave it at that for now. I should've taken pics tho... nice bit of kit, all touch-screen and wotnot.
I'll dig it out and mail it to you tonight.
I was going to ask you some questions about it anyway, seeing as you're the guru on this stuff :D
Guru?! If you mean I'm the best person to ask if you need something broken, you could be right :)
