hi all i got bad vibration when under braking on me z non turbo n/a . its quite severe when dropping from high speed and the brake pedal has a thumping sensation . so might be somthin loose there maybe. yet it passed the brake test on mot no probs so any of you guys could shed some light on it would be most appeciated cheers cully z :)
either - warped disks or fron tension rod bushes worn out - or both!
cheers bilky i shall investigate cully z:)
With feel back through the pedel usually means warped discs. The car shudders when you have warped discs or if the torsion bushes have gone.
But like Bilky said, it could be both as the bush problem shudder could hidden in the brake problem shudder.
Hi
Had same problem afew months ago.
First changed to poly bushes- still had vibes! Changed front pads-still got vibes!!
Then changed both discs, vibes gone:dance:
Arthur
cheers fellas cully z:)
