brakes binding! any suggestions for a quick fix.
Put the car in the garage for a new bearing, {which they couldn't do(?)} and then a couple of days later the brakes started to bind.
probably caused by a jammed piston, which is in turn probably caused by a worn dust seal.
take the caliper off and clean it up with some brake cleaner and see if you can loosen up the pistons and free it up.
If not you may need to pull the pistons out and replace all the seals and clean it up internally.....
If not then its a new caliper.
