Fao Smw1
got my TC working again :D
it was the abs channels that were screwed! it thought front was rear & left was right, apart from that it was fine ;)
iv loaded the zed.bin file now, is that the one your running?
changes i made for my car:
abs channels correct now
wheel diameters
upped the min rpm threshold to 1500
any other thoughts?
Originally posted by MikeGroves
Enable plastic tyre mode :D
tried that one, would you believe theres no such setting :D
See now if you had wired the ABS wheel sensors up correctly in the first place then you wouldn't have had that problem LMAO !!! ;)
Glad you got it sorted mate. I can't remember if you have launch or not but if you do then I would set that at about 2k rpm until you fit eagle F1's LOL.
In the wet setting are you getting any slip when you boot it in a straight line ?
erm, there is no "correct" way to wire them up, thats why you have to configure them in the software :slap:
nope, dont have launch.
its a lot smoother now the cut tables are configured.
driving home, the only problem i could see was im getting misfire at low speeds when pulling away gently, i was gonna up the min speed threshold up to 15-20 kph
