Boost Gauge check after JWT/POP install
It says in the destructions for the POP ugrade that comes with the JWT that "The boost must be checked with an accurate gauge to determine whether the boost pressure is in the range (12-14lbs). If the boost is too high 'Ping' or detonation may occur Jets can be ordered to correct high or low's"
Question. Should I get my boost checked after install? If so, who knows a boost gauge owner in the Berks area?
Simon (Ecu sat on desk waiting for Saturdays spanner session!!!!!!!)
Hi,
Yes, you must use an aftermarket boost guage to check your boost. Every car is different and your's may be to high/low. I called Power Engineering in Uxbridge to borrow theirs, they were quite happy to lend it/drive my car on a test run. (Yes - that's mainly a ford upgrade shop).
My car was spot on.
Remember, the psi varies on hot/cold days.
Disconnect your battery!
While you're in there check the ecu for error codes)
