greddy profec e-01
hi guys
does the all singing all dancing greddy profec have a turbo timer built in?? or do i have to use a separate one??
dewi
Dewi,
Sorry - I can't answer your question, but I'm also looking at a boost controller for early in the new year. You might be ahead on me on research so can I rack your brain?
A few people rate the Greddy that you mention, have you decided on this over the other options (Blitz, Apexi etc?) and if so, what makes it so special?
Thanks in anticipation of some help!
Nige
No it dosen't have a turbo timer, you need a separate one.
As for why it's better, it seems to have a better algorithm than the blitz one, dosen't overshoot as much and the boost dosen't vary as much with external temp as the blitz one used to.
It's also got a graphical display which is ideal for tuning it, you can even record and play back the trends. You can also log 2 other analogue and pulse inputs with an extra harness. That means you can record/playback RPM/Boost/MAF voltage & Lambda voltage which is ideal for tuning.
I think to get all that functionallity from the BLITZ one you need to buy the power meter or whatever it's called?
The Greddy one's cheaper too.
well thats told us has'nt it nigel LOL!!
john you really are sh*t hot with these things are'nt you,
hope i can get in touch with you after crimbo to set up my greddy and chip,
was thinking of the apexi avc-r but as it looks the greddy is king of the hill!!
the only thing is i have to get a separate turbo timer!
Well I am a control engineer, LOL.
I have had both though, so easy to make the comparison.
useful thread this - thanks guys
How much is the Greddy then - I'm cringing in anticipation.
...and what should I expect to pay to get it fitted and set up?
...and do you have a link where I can go look at one?
Ta:hyper:
Thanks Chris.
I've actually seen one in the flesh, but didn't know what I was looking at!, (on Scoops's car).
It's an impressive peice of kit, but I'm yet to see an install that doesn't look a bit 'home made'.
Is there anyway it can be fitted into the dash or something, and where on a zed can you put the remote? and it has a trailing wire from it too?
Shame!
What's involved in fitting it and setting it up?
