wet weather
my car dosent like the rain
just come home in it and it cuts out under hard acceleration
thought the eingine my be getting wet but had look and all was dry.
had apexi induction recently fitted could this be any thing to do with it??
steve
you like my 'tagline' huh?!?
with the induction - did you make sure you left the splashguard in place?? As well as air, they suck in water very well too, and as we all know, engines don't like water!!
I had a similar problem with mine after trying to ensure it was getting as much air as possible... doh!;)
hth
Rich
thanks guys
what is the splash gaurd all the bits they removed were in the boot looks just like the air box.
can i easily see the splash gaurd?
steve
separate from the airbox - thin black plastic contoured 'tray' right underneath where your apexi is. There's a possibility they bent it up out of the way when putting the induction on...
It's not particularly flexible though, so you might have to remove filter to get it back down.
Rich
thanks mate ill have a look at that tomorow.
steve
Hi Mate I got the same problem although both my splash guards are in place. I.e. the main one and the induction one.
On hard acceleration it cuts out and then runs shit for about 10 seconds and then it picks up again.
A little tip is to put duct tape on the bottom of the induction to keep the water out. can take these off in the summer.
I have vents in my head light panel which also lets water in I can't use the duct tape trick.
you can see in this picture the induction has been removed and you should have the main splash guard which attached to the front bumper under the car and also the induction splash guard which is held on by the brackets (should be supplied with the apexi induction - blue dots).
thanks alot mate that sounds like wot mine dose
cant find the picture though mate..
steve
steve
Stevo
I used to have this problem when I had a HKS mushroom filter and it was because I didn't have a splash guard. However, since having the dual filters that point up, I've never had the since.
Cos
steve
Oops I suppose a pic would help sorry mate :D.
ah i see now
rip it apart tomorow and have a look.
thanks:) :) :)
steve
