I have a MINES ecu which as I understand comes out of the factory set up to run with 440cc or 550cc injectors , not 370cc injectors.
I have been running the ecu with standard 370cc injectors at 14psi with no problems but will be having the tubs replaced next week with new standard tubs, so was going to put some 555's in at the same time to be able to run 16.5 psi .
now my question is if the ecu has been set up to run on 440cc injectors will it run like a bag of nails if I use 555cc injectors ??
Ryan
