advice wanted> changing wheel hub<
i need to get the wheel hub off to put some longer bolts in!
there is a small disc in the middle i presume i need to get out so i can get to the nut and split pin????
advice plz..or am i looking in the wrong place?
thanks jay
You mean longer wheels studs? I have put longer Nismo studs in and didn't take the hub off.
If you drop the caliper out of the way you can get the old bolts in and out through the back. Or should I say out and in.
hi i tried that but the back of the studs are too big,i cant get em out,.
They will come out, I have changed all of them. You have dropped the caliper out of the way? They won't come out with that in place.
There is enough space for them to come out of the back towards the bottom of the hub iirc. The dustgaurd thing got in the way a bit - but they DEFINATELY come out! I am sure I have done a mini write up somewhere. I'll look for it.
(edit) I can't find it - but trust me, they do come out.
i'll give it another go tommorow,the caliper and everything is off ,just when i tried knocking the bolts through they are being stopped by a obstruction at the back.i will take some pics to show you.
Yeah, chuck me a pic. I'm guessing you mean its hitting the dustgaurd to the disc. There is a cut out in this at the bottom iirc. Or you may have to bend it a bit.
Have changed the studs without removing hub also, so its not just james' imagination :D
sorted it,thanks guys.
they did come out guys,thankyou
jay
