5mm spacer on front....rear?
A mate has said about having a wider track on the front to the back might be a bad idea........is it best to space the rear aswell? I hadn't planned to. (my new wheels just catch the caliper) a 5mm spacer/shim will sort it.
Cheers.
Put it this way... my wide arches make the rear track about a foot wider than the front and the handling is now amazing ;)
I can't see that having it slightly wider at the front would make any difference.
Cheers Chris. Was just on the phone to Luke, chasing up and order and ran it past him. He said there's no need to space the rear other than if it looks funny that the front is wider.........I doubt if you'd be able to tell.
I've got 5 mm spacers on the front and none on the rear and my cars handling are just fine, also you can barely see the diference:dance:
