Which sensor gives the tempreture readings?
When car is warmed up temp gauge goes little bit less than half.
I want to install a temp gauge and read the temp in celcious and i want to know where to connect it.
Do u know the ECU pin number for that?
the new gauge will come with it's own sender unit which you'll have to fit into the coolant system somewhere near the stock temp sensors.
Vijay
Currently the temp engine readings comes from the coolant temp sensor?
Mine is disconnected and I still get readings on my stock gauge
Dont think your car would run properly without the ECU temp sensor :confused:
There are 2 senders on the top of the metal water pipe facing the large fan. The LH one sends temperature readings to the ECU, the RH one to the stock temp gauge.
Pete
Well actually it doesnt run properly at all.
I bought a new Temp Sensor and new OEM EFI harness waitting to be installed.
Now I am just trying to take some readings from the ECU to my Blitz SBC-ID device and I am trying to find out which pins to use from my ECU.
But if this what you are saying is right then it makes sense. I shouldnt get any readings from the ECU pin (Coolant Temp Sensor) because mine is ruined.
I manage to get A/F readings to the SBC and it looks quite cool. Especially with the graph. :)
