Amp Installation
I am trying to put in a amp & all the usual ICE stuff, and am bloody close to finishing, but at the moment I am stuck on how to get the power cable direct to the battery. At the moment I have it sitting under the glove box on the passenger side from the boot (then football started) and need to get it to the battery.
Can anyone help?
Daz:confused: :confused: :confused:
Do a search on here, this has been asked several times, and i think you will find there's a few places you can get a cable through the bulkhead.
There is a rubber gromet in the bulkhead behind the ECU which also serves as an AC hose.
You can fit the power cable through the same hole although make sure you fit the gromet/hose back properly.
Steve
I used the hole through the bulkhead on drivers side just a bit up from the peddles. If you pop the bonnet and look under there you should see some light coming through and if you look under the bonnet at the bulkhead on the drivers side you see the cable going through with grommet.
Geoff.
