October 10, 200323 yr For those of you who are running 14psi or there abouts what is your TDC timing set at. Just making sure I can squeeze every little bit of power out of the old girl for the RR day at the moment mine is set at 12-13 TDC , just wondering if it would be safe to take it to 15
October 10, 200323 yr The standard ginition timing is 15deg + / -2deg BTDC. When I had my first boost upgrade, my ignition timing was set at 13deg BTDC. I then fitted a JWT chip and reset the timing to 15deg BTDC while running the same level of boost. Technically, I don't see the point of increasing boost to a level where the ignition timing has to be retarded to stop detonation. A 1deg advance / retard on timing makes quite a difference on power output. There are timing tweaks you can do by setting the timing at 17deg BTDC. If you get detonation then you retard this setting until the detonation stops. You need to have a good ear for detonation when trying this and if your running stock turbo's then at least have a JWT or equivalent eprom upgrade. 12-13deg BTDC would be the normal amount of retard if you have stock turbo's & eprom! Steve E
October 10, 200323 yr Steve I have stock tubs but an upgraded ECU and intercoolers does the extra 1-2 degrees really make that much difference ??
