The alloys that i'm looking at are blitz 03's very nice but they are advertised as fitting NISSAN SKYLINE/TOYOTA SUPRA/LEXUS 300, now i thought skylines have the same fitting etc at 300's but i didnt know about the supra??
So wheels that fit a supra also fit a 300??
I dont want to buy them and find out they dont fit :rolleyes:
Kirbz
They will fit,however you need to supply the correct offsett;)
Well Big Roys Z wheels fit on his Supra but the Supra wheels would not fit the front of his Z If I remember:confused:
When I was shopping for aftemarket wheels, every supplier said that the 300ZX, Supra JZA80tt and RX7 all take wheels of the same size/offset.
Hope this helps......
Went to try the wheels tonight and well they fit i suppose but the car looks like bigfoot!! the fronts are fine but the back must have a massive offset cos they stick out about 3 inches more than my others.
Totally gutted :cry:
Can this be over come or am i on a loser??
If you have a wide kit they will probably look awsome and not need spacers.
If theres nothing i can do to make them fit mine let me know if you want them as i have first refusal on them and there quite cheep!!
Kirbz
I entered an ebay auction for Blitz 03's a while back, the fitment was for a soop.
The bolt pattern and offset should fit the Z, the only difference is the size of the centre-bore. Z is 66mm, soop is 60mm.
You can get 'spigots' - basically a ring which will fit in the bore-hole make make a snug fit around the hub centre.
If the wheels are for a supra, you may be lucky in the fact that there may be a 3mm spigot inside which could be removed and hey presto, they may fit a Z.
Alternatively the bore hole may be 60mm and you would need the centre to be machined-out :cry:
Dave
