TVs and room size
How critical is TV size in a room? I have a 36" CRT in a room which is about 12 foot by 11 foot. Is this too big ? I never thought it would be , but one guide I read said I need to be 11 foot from the screen !:eek:
For screens, you need to be between 3 and 10 times the size of the screen away to be safe.
Stuart
safe from what ?
Nar, not that critical; that room is fine.
If you can see the dots then you are too close.
More important is comfortable seating, good ventilation and
some other low level lighting not reflecting in the screen.
:dance:
I just love this little guy.
damn :( I'm now thinking I shudda bought a smaller screen.:mad:
ne1 got a bigger screen in a room of similar size ?
Yes, I've got a 46" widescreen and I sit around 11-12 feet away. It's fine.
safe from what ?
Radiation, frying your eyes.
It falling on you ;)
"Damage to viewers
TVs and videos emit non-ionising radiation over a range of frequencies. Although currently no proven adverse health links exist, the issue stimulates contentious debate and it is best to be cautious, by sitting at least six feet away from the screen and, after use, by switching off devices fully, especially in bedrooms."
Viewing distance recommendations
Try to position your TV so your eyes are level with the middle of the screen when youโ€™re seated. Also, consider the available distance between the screen and your sofa or chair. If you sit too close to the screen you may see visible scan lines or visual artifacts that will distort your picture. If your viewing position is too far from the TV, you won't experience the full impact of home cinema.
Use the guidelines below to determine how far you should sit from your TV.
Diagonal
Screen Size
Recommended
Viewing Distance
27in
6.75ft
32in
8ft
36in
9ft
40in
10ft
45in
11.25ft
50in
12.5ft
55in
13.75ft
60in
15ft
