Hi all
Is there an electronic wizard out there?
My Z is fitted with an alarm/flashers/central locking via IR remote
& my immobiliser via a key inserted to female connection. I hope this sounds ok? & no a load of bol--cks!
My remote is ok.
Me problem is, er? my female connector- which is on the centre console.
I insert key the thing bleeps code eccepted! great!
Pull up at girlfreinds, switch off. Collect girlfreind, insert key, NO BLEEP! F-in Z wont go! RAC called. He said my female connector to the immobiliser is worn & the copper wires in the connector ave add it!
Well to replace everything is going to cost me £250!
Ok know its not LOL but I have just put a low milage TT engine in mi car at the cost of £4K!
Now it is booked in to ave this done. But because of you chaps out there is there an alternative?
Do I just replace everything new? Or is some electronics wizard going to tell me I can get the female connector changed or repaired. Oh god that is long winded!!!!!!!! Arthur, sleep on it!
let me know the make of immobiliser, if it bleeps when you put it in then sounds like apollo 2002 or microscan.
if it has 3 pins inside and red led built in then it wll be.
Bob 07770 268705
Hi Bob
the set up is Serpi Star, does that help before I call?
Are they both Serpi Star? Alarm maybe but immobiliser may be different.
Have a look for the certificate which will have model number, if you haven`t got it then try and get me a pic.
No not both serpi star!
Immobiliser is Hamilton & Palmer? System Serial No 23006.
It has a red flashing light on console above Key.
might be able to help. don`t deal with HP but do use them when we fit trackers to cars that don`t have immobilisers. I will speak to tracker and see if i can scrounge one and get it to you.
Bob
Hi Bob
the model is a Vantage Matrix 1
is this any help?
Hi Bob
have contacted Hamilton & Palmer they can supply a replacement receptacle.
Why did I not think of trying to contact them before!
Sorry for the bother.
