what is it?
when the rubber pipe which leads from the rad is hard with alot of pressure and the revs go up?
then when you open the bleed screw let out some water the reves drop?:confused:
Are you serious? Letting out hot water is asking for trouble. You could get water boiling instantly when you reduce the pressure - you'll then get well steamed!
Anyway it is supposed to be hard and holding pressure when hot - if it was soft it would mean a leak somwhere.
There shouldnt be any connection with engine revs though. Cant explain that one.
