import parts?
Can anyone help me, I have to get my import 300 tt serviced & some mods, where can i get the bits from or can anyone recommend specilist dealer nearest to portsmouth are, who can do these jobs?
I know i might have to travel but where?
Also i need this stuff doing any idea how much for the supply & fitting of this,or just to buy & a seperate fitting charge & i will have to find a mechanic to do the work?
Full service,new timing belt,new water pump (while its all off),oil cooler for gearbox, water temp gauge,boost pressure gauge,
any help will be great!!
Sounds like you are doing the 60K service and http://www.courtesyparts.com do the whole lot as a kit I think.
Much cheaper than buying from Nissan here.
All the bits are the same as UK spec so you can either supply your own parts or just get your garage to sort it all out.
I'm not sure who you would be best using down your way though.
many thanks
found that site & ordering gear.
The only thing they didnt have were gearbox oil cooler & water temp gauge.
any ideas?
if you havent ordered the kit yet then order it through one of the traders on this site as they will probably be able to do it for cheaper.
i'm ordering that same kit as you (plus some other things like PCV kit, which is something you might want to change aswell) in the next few days from one of the traders, so you might want to hang on and see what price i get the stuff for.
many thanks
I will see how you get on, are you getting it fitted by dealer or private?
getting it fitted privately while my turbos are getting done. if you mean nissan when you say dealer, then i wouldnt go anywhere near them as they charge stupid amounts.
