is the stock boost really this crap?
Mine seems to be totally out, with my avc-r off, according to the avc-r it hits 45 kg/cm (which is about 6.5 psi), but my gauge goes up to just under 12 psi. Would anything be wrong?
Vijay
Couldn't comment on how accurate the avc-r is, but it does seem a little feeble, unless it's in safety boost.
With the AVC-R off, and the standard boost solenoid disconnected (as you do to fit the AVC-R), you'll only ever be running "safety boost" - because the ECU can't open the boost solenoid to bleed off some actuator pressure so that you hit standard boost - which is 7psi or thereabouts - so 6.5 would be very nearly spot on..
Not sure why your boost gauge reads so much higher though.. That is a tad strange - maybe it's just really *really* innacurate..
With my dsbc (blitz) when turned off i run
8.79 psi or .606 bar.
Hey Vijay !
I hope it isn't showing 45 kg/cm ! that's like 600psi or something...lol
Stock B-gauge is piece of crap.
Mine shows 9 psi when BC is off. (should be around 6psi)
My Blitz also shows 0.45 kg/cm2 when turned off...and that's what it should show.
Warren, are you're sure you have disconnected the stock boost solenoids ?
-Eric
[This message has been edited by lymon (edited 08-08-2001).]
300happy.gif Vijay, you worry me mate, you didn't really get all those scratches from some key happy, spotty erk did ya? No, you've accumulated them over time from not looking where you're going when yer driving...coZ you're too busy watching and fiddling with all yer electronics mate...LMAO! 300happy.gif
Tim
Eric,
I know my car goes, but yeah 600 psi is a bit extreme, as yours is its 0.45, but should the gauge read nearly double?
Tim - leave me alone!!!!!!!! You've got this all to come, what goes around comes around (lol)I can't wait for you to get your motor back and then we'll see!!!!!!!!!!!
Vijay
Believe me mate, what I've been through in Z ownership so far makes me very thick skinned! LMAO!
Hey don't worry, I've got a Techtom to work out yet...will probably stack it first day...LOL!
Tim
