car ramps
Has anyone built a set of long low slope car ramps that work with a zed ?
If so, do you have sketches with dimensions and material list.
John
Might be able to get hold of some of these John. I will find out tomorrow mate. ;)
They look quite neat Andy........might make some of those up for myself. The one's I maybe could've got would've been metal from a motor factor............they won't beat those for FREE!
Thanks both of you.
Those look interesting Andy, looks strong enough.
John
These are what I use John.
Basically chopped down some wooden sleepers and screwed them together with a lick of black exterior paint.
Not really worth bothering to make your own
when you can buy a 2 ton set for about £16 -£17.
Where can you buy a 2 ton set for £16 ?
All the car ramps I have seen (£29) have too steep an angle and will not clear the 300zx's body ???
John
Your car won't make it up the ramps without scraping the front bumper :eek:
Thats right Stuart,
Thats why you have to make your own with a very shallow angle - about 10 degrees.
John
I'v got 6x 2-poster ramps & 1x 4-poster flat bed ramp with full electronic 4 wheel alignment facilities
is this what you mean!?!? :D :D
No, I was thinking of a simple wooden one you can build for about £40 worth of wood.
John
Some people are just down right spoilt :D :D :D :p
Robin
That was the price quoted when I called a motorists'
shop in a local town.
Good point about the danger of fouling bumper so
maybe bespoke ramps are needed.
Be bold, dig a hole and make a nice lined inspection
pit:D
A pit would be great, (it would also trap some of the local ankle biters too!)
Yes, when you slide standard car ramps up to the front of the zed they touch the bumper and are still a mile away from the front wheel.
John
You could try asking at a technical college whether
the metal working section would make you some
for a small fee.
Maybe you know a welder?
Ad in local shop window?
Had the wood and paint already so really it cost me nothing but I see your point.
I plan to make them out of something like engineering board, its like shavings of wood compacted together, unlike chipboard (which would probably do, as its a solid structure)
Get 2 4ft x 8ft sheets, have B & Q cut them (stacked one on top of the other - to save money for the cuts) into 12" wide strips running in the 4ft direction. You now end up with 16 strips of 3/4" x 12" wide x 4ft long. (will fit in the back of the 2+2 zed)
Glue and screw them together, as in the attached drawing.
That looks fine. Might nick that idea.
Maybe you could add a couple of extra boards for the
front and then a lower version for the back wheels
so that the car does not tip so much.
If you have access to the equipment you could
chamfer the leading edges and perhaps rout
a section in the boards to cut the weight down.
Gluing with suitable adhesive, screws not needed.
Oh for double garage and a proper lift.:(
Yes, you could lighten them up a bit I guess, I calculate their weight at about 50lbs each. But I will only be dragging them about 25 ft out of the garage. (garage too small to fit the car in, and anyway, driveway between houses too narrow.
Why do they build these "garages" so small, they are not garages, just toolsheds.
John
Perhaps you need the exercise?;)
Yep, they're smallish and not always in line with the drive
either.
To be fair, the Zed is a bigger-than-average motor.
I had a g. specially built for my Zed but I so enjoy
seeing its elegant parked outside that I don't actually put it
away tho' I think that I will this back end/winter.
(There's a cctv camera in there so I could still
keep an eye on it.)
hmm, should I have put 'her' instead of 'it'?
