Thinking of getting a Boost Controler and Dump Valves, whats the best ones to get people?
Will i Need a fitting kit etc?
Thanks poeple
Gotta be said buying crappy bleed valves for a 300zx is not the way to go.
Having had one on another turbo car i would never again, boost spikes and generally unpredicatable.
If you dont want an electronic controller get boost jets instead.
You want to buy bov's with fitting for a Z, they quite often appear on ebay.
Thanks ppl i would like a electronic controler not a bleed valve one! also thinking of fiting a SS Zorst too.
Just a quick quesion, but if you change the boost do you need to remap the ecu everytime to allow for the change in boost to keep the mixture and timing correct?
No but you should really get your ECU chipped with JWT or SE or some thing like that as increased boost on stock ECU will cause detonation with a little boost increase.
You dont have to remap your ecu every time you change your boost and you can even change your boost as you are driving.
Stuart
f**k that up:D
As SRRAE said you must get your ECU chipped before you raise the boost as you could cause damage to your engine. as for a dump valves why do you wont them, unless you like the noise they make, as the Z already has them recalculating ones that is, witch are better than the ones that dump to air.
