gurgleing
anyone hear had gurgleing sounds comeing from the n/s front wing? i spent 3 days bleeding the cooling system thinkin it was an airblock or headgasket. but it turned out 2 b some exhaust condensation valve stuck open under the wing. dont know if anyones interested 2 know that but it may save u some hassle.:D
yep thats the thingy:D just took mine 2 bits an cleaned its fine now:cool:
Yeah the old AIV. I've still got to sort mine.
Geoff.
I sorted mine in a kind of permanent fashion. They are now applying air to the floor of my mums garage :D Remove and plug whats left (pipes coming off exhaust and vac line). Yes, you will run slightly rich under certain conditions but not enough to affect the car. In fact, I'm sure the AIVs only work when the engine is in 'closed loop' mode, using the O2s to set the mixture. Remove them, reset the ecu, and have fun :D
