Radio ariel.
I am in the process of fitting a new CD player in my Z but the ariel connection is not compatible with the new unit. Is there a conversion plug I can buy. If so where from, or is there another way around this problem.
Billy
there is a convertor that you can get from most audio specialists for about £15
or you can buy a standard solder type connector for about 50p & cut the old end off & solder the cables to the connector - theres 2 cables (2 aerials!) solder the outer shielding to the outer part of the connector & the inner core to the centre pin. job done! :D
Yes you can buy an adapter - my Z had one already fitted so I don't know where from :(
The other option is to cut the old one off, go to Maplin or a car audio shop, buy a UK plug and fit it instead. Will only be a couple of quid that way.
LOL Looks like you beat me to it Paul, I must type faster in future!
you got an auto keyboard?? :p :p :p
Thanks guys.
Will get the soldering iron out.
