August 3, 200323 yr i cant afford a boost controller at the moment so was going to try the boost jet method. can someone tell me what size jets i need for about 14 psi.. also where do i put them. cheers ..lee14 psi
August 3, 200323 yr try this site http://www.zhome.com/ZCMnL/PICS/boostJets/boostJets.html You can use mig welder tips as boost jets they come in different sizes so you can get different amounts of boost. but you must have a good after market boost gauge as the one on the car is no good. ----------------------------
August 3, 200323 yr AFAIK - I believe that 14psi would be attained with 2 x 1mm tips. I would get that confirmed though. I may be wrong. I think one 0.6mm tip on one side alone will produce around 11-12PSI. Get it checked before you do anything. Cos
cheers
..lee14 psi
