Is anyone taking ConZult + Laptop to Billing?
Hi
If anyone is taking a laptop and conzult to Billing would you mind hooking it up to me zed to help diagnose my possible TPS/autobox troubles?
Thanks in advance :)
Pete
what probs are you having pete? im only asking as im also having probs with power mode constantly switching and holding gears for too long.
Hello Pete,
If I end up making it to Billing, then yeah I'll bring mine.
Vijay
When starting up the Power button flashes 16 times :confused:
When driving the engine note sounds whiney and holds 2nd gear for ages. Kickdown only works intermittantly. When booting it the gears change upward too soon ie about 5000 revs.
I think the TPS connector wire was broken when fitting new PCV hoses, I've got a new one but want to confirm the TPS signal is what is upsetting the autobox, before I get the wire cutters and soldering iron out and botch it before Billing ;)
i've tried the autobox diagnostic upteen times but cant get it to work :confused: The power light just flashes 16 times agin, half way through the procedure :rolleyes: :confused:
Pete
I will have my Conzult there Pete I am on TA2 , also I know so will Danny Zaat and he will be selling selling them.
Jeff TT
Yep - I'll be selling them from the DTA-motorsport stand (next to SE Nissan & opposite the 300zx.co.uk plot - I think). Will have one to demo so time permitting can hook it up to your car to have a look see!
Cheers!
Danny
An update on my problems: The conzult at Billing confirmed the TPS was the fault (Thanks Jeff :), and Danny for the offer on the day :) )
Went to John Dixon's to fit rear suspension and play with the new TPS and wiring. When the new TPS was on, the autobox fault was still there - so must be the wiring we thought. A multimeter pointed to a problem with the loom wiring to the TPS :(
First of all tried the ECU end, wiggled the loom-ECU connector and *click* - the revs immediately change note and drop to normal idle! Woohoo! :D:D Car runs brilliant now, no power light flashing or odd gearchanges. And the ALC works too :D:D
So check your ECU connection :o :o
And a big thanks to JD for the work, again!!:)
Pete
